Knowledge base articles
We tell you what we're doing, you tell us what we're doing good or bad.
Post by steve_earwig » Thu Apr 03, 2008 4:17 pm
Just an idea so you lot know what I'm burbling on about :cheesy:
First up: mjb's "how to remove the dash" post viewtopic.php?f=3&t=3900#p37248
Re: Knowledge base articles
Post by Welly » Tue Apr 08, 2008 10:07 am
The fix for the ENGINE TEMPERATURE TOO HIGH message:
viewtopic.php?t=1452&start=0#p13555 (courtesy of Foggy)
2005 Volvo S40 T5 a bit pampered
2010 Citroen C4 1.6 HDi turbo de' explosions
Post by steve_earwig » Tue Apr 08, 2008 6:45 pm
Surely the magic clothes peg belongs here too :cheesy:
viewtopic.php?f=2&t=4205&p=40013&hilit= ... peg#p40013
Post by Welly » Wed Apr 09, 2008 4:50 pm
Air filter and pollen filter changing:
viewtopic.php?f=1&t=3870&start=0&st=0&s ... len+filter
Post by steve_earwig » Fri Apr 11, 2008 10:32 pm
D8 1,9 engine swap:
viewtopic.php?t=2852
James is THE man!
jameslxdt
Post by jameslxdt » Sun Apr 13, 2008 7:23 pm
Post by teamster1975 » Tue Apr 29, 2008 11:05 pm
Steve_earwig's Rad Fan diagnosing
viewtopic.php?f=3&t=2974&p=38735&hilit=+fans#p38735
Post by teamster1975 » Fri Aug 22, 2008 12:17 pm
mjb's how to fit Aux belt to 2l tubby
viewtopic.php?f=1&t=5547&p=54227#p54227
Post by teamster1975 » Mon Sep 22, 2008 10:17 pm
How to remove front coil spring & strut
Mr P on Yahoo Answers wrote:Have taken the struts off mine a few times now.
Try getting a ring spanner and torx to fit the top of the strut first, and loosen it while still on the car(- don't take it off yet!)
Wheel off, and support etc.
Take out front section of wheel arch plastic.
The front wishbone seems biased to spring up - you will need a bar and rope around it to force it down off the track rod end.
Take the main bolt out of the back of the lower end of the strut - completely out, and use WD40 in the socket at the lower end.
A heavy copper hammer is good here.
Before doing this - use your spring compressors to make life easier.
3 bolts at the top and it will come out (with you standing on your bar/rope on the wishbone.
You may want to put a new top bearing in there too. - They're cheap enough if corroded - which they usually are.
Paint with waxoyl before fitting back on and you won't have problems.
Careful not to stretch the brake lines.
Post by steve_earwig » Mon Sep 22, 2008 11:07 pm
I'd still rather pay £15 for someone else to do it :P
Post by teamster1975 » Mon Sep 22, 2008 11:17 pm
steve_earwig wrote:I'd still rather pay £15 for someone else to do it :P
So would I if I could get it done for 15 quid! :mrgreen:
