What is your level of mechanical expertise?
Polls go here.
None, I always go to the dealer.
0
No votes
None, I use a mechanic.
2
5%
I can do simple stuff that doesn't require many tools, like change an air filter.
4
10%
I change my own oil, can get wheels off, and macho sounding stuff like that.
9
21%
I can do most stuff, but its not my profession.
22
52%
I am a mechanic.
5
12%
I am the dealer, thou shalt kneel in my presence (and get your wallet out).
0
No votes
Total votes: 42
rwb
Post by rwb » Wed Dec 15, 2010 11:26 pm
jamjar1383
Re: What is your level of mechanical expertise?
Post by jamjar1383 » Wed Dec 15, 2010 11:37 pm
I am a mechanic (ford trained many moons ago), although not a very good one when it comes to french cars it seems :lol: :lol:
d9 hdi 90 rapier estate
rwb
Post by rwb » Wed Dec 15, 2010 11:39 pm
Better than me :) (I wasn't going to confess until there were some more votes.)
Post by teamster1975 » Thu Dec 16, 2010 2:08 am
DIY mechanic me, with lots of tea and cigarettes for the bastard jobs :cheesy:
Post by Welly » Thu Dec 16, 2010 9:22 am
I can, and have done, all kinds of jobs in the past (some with a bit of assistance) but I lack the tools and equipment.
Recently I considered changing the pads all round on the Volvo but by the time I'd bought some more kit (like a trolley jack, copper grease, brake cleaner 7mm allen key etc..) it was cheaper really to pay my mechanic and I stayed in the warm doing my work :|
Have you ever noticed that when you do a job yourself there is some self doubt hanging around afterwards like "did I tighten those nuts fully?" etc :o whereas when someone else does it for you you don't even give it a passing thought :?
2005 Volvo S40 T5 German Diesel botherer currently lacking front tyre grippage
millard
Post by millard » Thu Dec 16, 2010 10:22 am
Welly wrote: Have you ever noticed that when you do a job yourself there is some self doubt hanging around afterwards like "did I tighten those nuts fully?" etc :o whereas when someone else does it for you you don't even give it a passing thought :?
Haha, and I thought it was just me :cheesy:
I just did the cambelt and a few other jobs and then sent the missus on a 250 ml round trip with the car. I was waiting all night and the next day for an irrate phone call from her,,,didn't happen though - mostly thanks to advise from the forum :wink:
Post by steve_earwig » Thu Dec 16, 2010 11:14 am
I've no idea how to answer this truthfully. In my younger days there wasn't much I'd have a crack at but on old clunkers it didn't really matter. I've rebuilt a few engines, made 1 good gearbox out of two broken ones, changed numerous clutches, brakes, driveshaft gaiters, shocks, springs, blah blah, plus normal servicing stuff beyond count. Once I started driving newer cars I thought I'd have them worked on professionally but a couple of cock-ups later I gave up on that*. These days I can get stuff done for almost no cost, so my last service on the D9 was done by a mechanic. And hey, for the first time ever I didn't end up with engine oil everywhere!
*This goes with the above posts - I had the gearbox oil changed in my 2nd BX 16 valve by a well known Citroen franchise who buggered the 'box up by putting the wrong oil in it, so for the next job (which I can't actually remember what was for) I took it to another garage, who gave me my car back with all the wheel bolts loose. After that I decided I couldn't make any bigger cock-ups than these guys so I went back to the DIY. Since I've come here and the labour's cheap (or even free 8) ) it's going in to the workshop. But I know the mechanics as mates, I trust them, plus I get to watch & lend a hand. Actually, yesterday I was meant to go shopping but, as the workshop's just around the corner from the supermarket, I helped change the thermostat on a Mercedes Sprinter instead :cheesy:
DiscoPol
Shiny New C5 2.2 Bi-turbo!
Post by DiscoPol » Thu Dec 16, 2010 11:32 am
Since changing from the 406 to the tractor (Discovery 1) i have tackled jobs that would have been beyond my level of confidence in the past, like the recent change of all 8 wheel bearings and the required stripping down of hubs,stub axles, swivel joints etc etc, there is always that niggling self doubt with any jobs i do, but im hoping this will pass with more and more successful jobs ticked off the list, i once tried to change the clutch in an old 205 gti i had, it was the death of the car and resulted me selling it as scrap with its guts spread all over my garage floor :oops:
i have always believed in doing services and the like myself as i detest paying somebody to drain oil and change a couple filters but major engine work i think i would still pass on as its all a bit of a mystery to me beyond swapping out old for new.
i once swapped an engine in my old series 3 land rover with the help of a mate, we took out a tired 2.25 diesel and stuck in a wopping great big perkins thing, that was easy though really as it was just bolts off, bit of welding and drop perkins in, bolt back up :cheesy:
luckily im now in the same situation as Steve re the labour costs, cheap as chips here, its just the parts are extortionately expensive for land rovers in Poland, so for the next big job i will be ordering parts from the uk and then just finding a local "man that can".
in reference to the wheel bearings i had to strip down the hubs about 3 times each as i was convinced i hadn't tightened things up enough or over tightened them, so a days job was spread out over about 2 weeks with my constant fiddling and checking on an almost weekly basis.
Post by Gary406 » Thu Dec 16, 2010 11:48 am
change my own oil get wheels of and stuff sounding like that :lol:
HimBigChief
Post by HimBigChief » Thu Dec 16, 2010 8:09 pm
Do pretty much everything myself, but if I do have to go to the garage I have certain ones which I trust to do different jobs. Done a few engine swaps in my time and my 309 I've built up from a shell so I'm not averse to most jobs, although some engine jobs I'm a bit wary of.
Image Image
Busman
Post by Busman » Thu Dec 16, 2010 9:16 pm
I would class myself as a competant DIY mechanic with some comercial vehicle experience as well. Got into doing stuff myself after being the victim of some fairly basic cock ups by garages. I like to think i know my level of expertise, but will tackle most stuff.
Tip of the day, buy good quality tools, they do the job better and last a life time.
2003 HDI 110 Rapier Estate
1999 306 1.8 petrol.
plod
Post by plod » Thu Dec 16, 2010 9:32 pm
Used to do more or less everything myself, but where I live now, it's shared parking and on a slope so not really practical to be doing anything there.
The guy who I bought my car is a real good friend, and a mechanic, so he does most things I can't practically do given the circumstances
Although if I had a garage, i'd certainly have a go at anything
1999 D8.5 HDi GLX - Sold :(
Post by mjb » Wed Jan 05, 2011 3:19 pm
The only stuff I can't/won't do myself is bodywork. However having said that I'm going to have an attempt at re-painting a green bumper for my sat grey coupe because I got it dirt cheap to replace the one being held together with duct tape :lol:
Welly wrote:Have you ever noticed that when you do a job yourself there is some self doubt hanging around afterwards like "did I tighten those nuts fully?" etc :o whereas when someone else does it for you you don't even give it a passing thought :?
Actually it's the other way round for me! :lol:
andymacg
Post by andymacg » Fri Feb 25, 2011 2:45 am
technically im a trained mechanic, learnt my trade in the army although its been 12 years since i did it proffessionally and theres a hell of a lot of difference in working on 4 ton bedfords and landrovers and on modern motors
mind you I still do all my own maintenance, last year i rebuilt the gearbox in the wifes discovery and get roped into servicing my dads pug 306
jolly green giant 1.8 16v LX estate
Post by lozz » Fri Feb 25, 2011 3:08 am
Iwas practicly born with a spanner in my hand,
my dad was a mechanic and he had me changing clutch plates in vauxhall vivas @ 11yr old,
ispent many months @ college training to be a car mechanic and idropped out as they had me doing stuff ialready knew,
ive learnt enough to get by with working at Garages ,
Working on cars bores me now ive lost interest in them
