BSI air con relay replacement.
Knowledge Base Articles
Locked
Malc
Post by Malc » Sun Sep 08, 2013 7:26 pm
Will go for brevity and hope the illustrations speak for themselves.
Relay Ripca 2032 complete with loom and a smidging of soldering expertise required.
Remove and disconnect the BSI and free up all rpt all the plastic lugs (my method as illustrated) and gently prise off the BSI lid.
The relay is directly opposite the middle and lower vent slots and schematic (taken from another site) as shown directly below..
It is essential at this point to test the relay for contact failure before proceeding!!
The next step requires gentleness and patience. Gently push a small screw-driver or similar between the relay and pcb heating the solder terminals at the same time with the soldering iron. Eventually the relay will prise downwards until it is free from the pcb. Once free crush the old relay to remove from the space and clear any remaing debris.
Place the Ripca 2032 relay as shown threading the wires through the hole conveniently provided....
Wire the relay to the solder terminals as shown.
Relay wiring information. I chose this relay as others have a diode across the relay coil which will require wiring to the correct polarity.
Voila air-con up and running as new!!!!
Re: BSI air con relay replacement.
Post by Doggy » Sun Sep 08, 2013 8:03 pm
Very good how to, we'll done. 8)
Never had to do one myself, but if I did, I would certainly opt for mounting it as you have, not bring a soldering maestro.
Do you know whether the original relay had an integrated diode? (If so, you really need to add one to protect the relay driver from the reverse voltage spike de-energising the coil generates).
Malc
Post by Malc » Mon Sep 09, 2013 9:01 am
Doggy thanks for your posting and your comment on driver protection noted.
The original relay (now no longer available) has no diode hence my choice of Ripca 2032. See datasheet pdf from link below.
If my old 50's electrical theory is correct when the relay is de-energised there is a back EMF which delays the action of the relay somewhat and the reason for the diode (when such magical solid state devices came along) is to discharge this back EMF instantly.
http://www.fujitsu.com/us/services/edev ... n010n.html
Locked
