trip computer installation
Knowledge Base Articles
Locked
Re: trip computer installation
Post by mjb » Thu Mar 27, 2008 9:01 pm
1368 is beige in colour and my V6 averages 23.1mpg on the way home from work
8)
Post by steve_earwig » Thu Mar 27, 2008 9:15 pm
mjb wrote:...my V6 averages 23.1mpg on the way home from work
Ouch!! :shock:
Post by mjb » Thu Mar 27, 2008 9:20 pm
Ouch!! :shock:
3 miles, cold engine, fair traffic and a right foot that's not as light as it used to be :lol:
I was amazed to see it saying around 50mpg on the screen as I was coming down Keele bank though. 4th gear no throttle should mean 99.9!
Post by teamster1975 » Fri Mar 28, 2008 2:33 pm
Well done that man!
Just got to get mine fitted now!
Post by Welly » Fri Mar 28, 2008 3:02 pm
The D9's display goes up to 999.9 MPG for some, useless, reason.
Well done fella for having the guts to splice and connect all this up (I haven't got the knowledge :( )
2005 Volvo S40 T5 a bit pampered
2010 Citroen C4 1.6 HDi turbo de' explosions
Post by mjb » Fri Mar 28, 2008 5:06 pm
Welton wrote:Well done fella for having the guts to splice and connect all this up (I haven't got the knowledge :( )
3 scary points:
1) Cutting what I hoped was the fuel gauge wire
2) Drilling a hole in the bodywork and hoping it led to somewhere I could get at from inside
3) Cutting 1368 when I couldn't actually read the last digit and worked out what it was by identifying every other wire in the loom
Post by STALLED » Wed May 13, 2009 6:56 am
Question - you can get a basic external temperature gauge which just displays two digits - not like the multifunction screen on the GLX's in the UK...
Would it be just as simple as plugging in the screen and wiring up the external temperature gauge into the plug in the door. - I can get both items from a wreck? The wreck is a 2.1TD, I don't see why it wouldn't work as it's not reliant on the ECU?
Cheers,
Joel
Post by mjb » Wed May 13, 2009 9:07 am
Should work. Can't see the basic display needing more than 4 wires: 12v, 0v and 2 wires to the thermistor in the wing mirror
Post by STALLED » Wed May 13, 2009 9:22 am
mjb wrote:Should work. Can't see the basic display needing more than 4 wires: 12v, 0v and 2 wires to the thermistor in the wing mirror
I already have the plug behind the coin tray - if the plug is at the bottom of the passenger door...it should theoretically work with no modification if I install the temp sensor at the bottom of the mirror - ie Plug and Play?
Post by mjb » Wed May 13, 2009 9:39 am
depends if that plug's attached to the temperature sensor in the mirror
kerman19
Post by kerman19 » Wed Jul 01, 2009 8:09 pm
Hello,
I've got a 1999 406 2.0HDI(110) GLX, registered in June 99', which has the MFD fitted by default because of the Radio/CD Changer. It was originally set to position 4 on the MFD to display only the temp and radio (though the radio is missing from the MFD due to an aftermarket headunit being fitted by myself). I've since changed it to position 3 which by default displays temp and range, it gives me the temp like before to the left side of the MFD but ---M for the range.
I guess my question is, can the MFD be installed in a 2.0 HDI? And what are the chances of the Wiper Stalk button functioning if replaced with a stalk which has the button, or is it quite probable that i'll have to fit the wires for that too?
If you could point me in the in the right direction for diagrams or software I can "purchase" in order to get the information I require that would be grand, I've got Autodata but it doesn't seem to contain any information regarding the MFD!
Thanks,
Phil
1999 D8.5 HDI (110) - Quality french engineering, not.
kerman19
Post by kerman19 » Wed Jul 01, 2009 8:19 pm
Tell a lie, Autodata does contain some information regarding the MFD under additional diagrams, this is what i've found so far for the 2.0HDI.
http://img40.imageshack.us/img40/95/mfdl.jpg
Post by teamster1975 » Wed Jul 01, 2009 10:20 pm
Have a search through Eoin's posts in the electrical section; he's got it working on his D9.
The trip functions need to be enabled in the bsi which means a visit to a dealer so they can turn the options on.
Edit: Here's Eoin's post :)
kerman19
Post by kerman19 » Wed Jul 01, 2009 10:38 pm
I forgot to mention it's a D8, although HDI kind of a transition model, best of both worlds!
Thanks,
Phil
Post by mjb » Wed Jul 01, 2009 11:08 pm
If there's a wire 1368 coming out of your ECU you may be in luck, but I think they're specific to Bosch ECUs and I don't think any of the Diesels have that. Research in this area is somewhat light though...
Locked
