Glow plug relay renewal
Knowledge Base Articles
Locked
karlosantana
Post by karlosantana » Thu Dec 23, 2010 6:37 pm
You will need
* 10mm socket
* 10mm spanner
* 8mm socket
* Ratchet
It's fairly simple, this needs doing if your getting a long start before the glow plug light goes off, or in my case was going off too soon.
It's located on the right hand side on the 1.9dt sorry dont know where it is on other models. Its under a plack plate like below
Now you'll see a 10mm bolt on the left handside of that photo, remove it catch the bolt!
You'll then have this!
Simply replace it, it has two nuts, one 8mm the other 10mm undo them unplug the plug. Fitting is reverse of removal, job jobbed :D
Cheers
Kyle
Reason: pics copied to 406oc photobucket account
karlosantana
Re: Glow plug relay renewal
Post by karlosantana » Thu Dec 23, 2010 6:38 pm
Again is it possible we can have this put on the Knowledge basey thingy please?
Cheers
Kyle
Locked
