Flashing STOP Driving me NUTS! Fixing corrosion inside BSI!
Knowledge Base Articles
Coops
Location: High Wycombe during the week, North Yorks at the weekend
Re: Flashing STOP Driving me NUTS! 2001 110HDI Advice anyone
Post by Coops » Tue Jul 27, 2010 11:54 pm
Try this thread, which details some of the problems you might get with water in the plugs in the driver's footwell, as well as how to fix it.
viewtopic.php?f=10&t=12118
Hope it's of some use and you get it fixed.
Cheers
Tim
supercharge
Post by supercharge » Thu Jul 29, 2010 9:49 pm
cheers coops, i had a look before i started my adventure on solving the problem...
went through mickeys post a few times to get my head around what it could or could not be, before i started i had paid a visit to the main stealers to get some "expert advice" and a "good value quote" mmm now the fun bit, after leaving the car with them for an hour, i came back (in another hdi to show how loyal i am!) to a nice, 20 year working at the main stealers chat with a top workshop manager...
cutting a long and boring story, very, very short, £780 + parts to fix what ever it was that was causing it, unless it was the ECU and then it would be MUCH more... so after picking myself up, thinking about having it done there... for 3 secs, decided to take another day out and get on with trying to fix it myself...
started with a notepad, a running order of things to do and complete in the right order, some wd40, an airgun, a few torx bits and some chewing gum to stick things back if i screwed up...
started at the battery / fusebox / black gadget things near battery, stripped everything down and started to clean where ever i could see rot and green copper corrosion...
all the pix are super high res for anyone else with a similar problem to solve...
got a bit further and found some more rust etc
cleaned all the stuff in order and still no luck with the poxy bleeping stopping!!! so onto the inside cleaning...
the bsi unit, was a right pain to get out and i can clearly see that this is where most non ***techy*** diyers would struggle like hell not to damage both the wiring and the plugs when "pulling" it out of the tight gap...
time to see whats going on inside!!! bearing in mind this is now 3 hours later...
interesting, there are a number of soldered elements that look like someone else has been in the box, so on closer inspection...
as can be seen, the two chips have both been burnt around the connectors, i am unsure if this is common, so out with the airgun again!!! cleaned everything up, wd40, no green rot on the copper and popped it all back together... thinking this is it, its going to work like a treat... guess what... it still did it!!!
so 4.5 hours later, with a completed list, a few new error codes and sore fingers, i thought sod it, i am NOT going to the main stealers, i am NOT spending money... so got the 3 main cables on the BSI, switched the ignition on again and pulled them off in order until i found which one controlled the dash... it was the GREEN one! sprayed the hell out of it with wd40, dryed it with the air gun, got my dremel out with the tiny weeny roto brush and cleaned the connectors one by one until they shone... put it all back together, did a BSi reset and...
IT STOPPED THE POXY BLEEPING!!! so i quickly and i mean quickly put it all back in the BSi slot, which even after 12 times taking it out is still a right pain to do... and started her up... YES it works... so there we go... 5 hours and 4 coronas later, i went outside and just tried it, she is still not bleeping, the last error codes i will read in the morning and post to see whats left to do...
THANK YOU to all who bothered to help, unlike a LOT of other forums, everyone actually took the time to answer, instead of making it up as they went along!!!
now onto the other 2 Hdi's!!!
sc
Reason: Pics moved to 406oc photobucket account
Post by teamster1975 » Thu Jul 29, 2010 10:15 pm
Well done mate, excellent bit of troubleshooting! 8)
jasper5
Post by jasper5 » Thu Jul 29, 2010 10:21 pm
Great stuff, well done 8) :D
mickeydread1122
Post by mickeydread1122 » Thu Jul 29, 2010 10:28 pm
nice 1 mate at least you managed to get it sorted and im happy for you and you saved yourself some £££ from the stealers. a problem shared is a problem solved.you highlighted something that i had forgotten to mention about the badly corroded wiring by underneath the battery due to acid leakages that can cause some of the lectrical faults on these Pugs mate.
I am absolutely thrilled you solved the problem, imagine taking the BSI unit to bba ( £120 ) for reconditioning then they wipe out all the data inside it and then you look for some1 with PP2000 or at the stealers to reprogramme it to your car.this is what nomally happens to the BSI unit when 2 or three drops of water gets inside of that unit and how much stress,anguish and grief it causes when it starts to give all sorts of electrical problems.
:lol:
Post by Doggy » Fri Jul 30, 2010 12:22 am
A really good solution, that could well assist others.
Suggest it's moved to the KB?
Post by mjb » Fri Jul 30, 2010 12:32 am
Nicely done!
supercharge wrote:the bsi unit
<snip>
The pictures are blurry but that just looks like excess lacquer on the PCB - quite common on low-tech electronics due to cheaper less precise manufacturing processes
mickeydread1122 wrote:you highlighted something that i had forgotten to mention about the badly corroded wiring by underneath the battery due to acid leakages that can cause some of the lectrical faults on these Pugs mate.
Since when? I've never heard of a leaking 406 battery causing problems. There's a drain plug in the bottom of the battery box which prevents leakage into the engine bay. The fuseboxes are inches above the tray and the main wiring harnesses are on a bracket which puts air between them and the ledge the battery box lives on...
The only vulnerable point is the chassis earth located just behind the headlamp, but that just suffers from the same general corrosion everything else on the car suffers from
FWIW, the plate on bottom of my battery tray is horribly corroded from battery acid. The bodywork underneath it however is pristine. The paint is in even better condition than that on my bonnet!
Post by Welly » Fri Jul 30, 2010 8:24 am
Sorry, I missed this thread, well done fella!!
I bet you're chuffed with the results, it's cost you nothing but your own time and saved you a fortune!
2005 Volvo S40 T5 German Diesel botherer
Post by Captain Jack » Fri Jul 30, 2010 9:25 am
Well done!
And to think Peugeot wanted to scrap the car because of this.... idiots. :evil:
2013 - ????: 2007 Peugeot 407 2.2 HDI 170bhp Executive Saloon (mapped to 213bhp :twisted:)
Post by teamster1975 » Fri Jul 30, 2010 12:07 pm
dogslife wrote:A really good solution, that could well assist others.
Agreed!
Locked
