FAQ - 406 D8 petrol (Excl. V6) running and starting problem
perils
Re: FAQ - 406 D8 petrol (Excl. V6) running and starting problem
Post by perils » Tue Apr 28, 2009 9:02 am
***UPDATE***
Hi guys....
Got my 406 back from Autosolutions here in Reading..... Still not fixed !!!
I will now type in exactly what is written on the invoice..
I just what some of you on here to give me your opinions as to their diagnostics please..
Here goes..
"Investigate cause of erratic engine idle, misfire and power loss. Carry out DIAG2000 fault code and running test. Carry out engine ECU firmware download. Re-initialise engine ECU and road test.
No faults were recorded in the ECU memory.
The running parameters check highlighted a fault with the engine ECU's interpretation of the coolant temperature (reading decreasing as temperature increased). This fault will cause poor mixture and idle control. The download and reset has rectified this problem.
The misfire is not apparent with a hot engine and may be caused by sticking cam followers (a common fault with this engine)."
There you go, thats the report I got back.
The car still runs lumpy until hot (check my previous posts for full details).
The car is a 2001 D9 2ltr with 48k on the clock. In top condition other than this running problem....
Getting to the stage now where if I can't get it sorted I'm going to have to let the car go and start with something else. This is really bugging the hell out of me...
Is this also true about the cam followers ??
PLEASE HEEEEELP !!!!
Cheers
Nick
Nick
2001 Yreg 406GTX
Post by Welly » Tue Apr 28, 2009 9:18 am
I certainly haven't heard it's a "common problem" at all.
In my opinion if you've got sticking cam followers you'd get some ticking noise along with the lumpy running.
It's probably something really silly and cheap but finding it could be tricky :frown:
Dare I suggest going to Peugeot?
*hides*
2005 Volvo S40 T5 a bit pampered
2010 Citroen C4 1.6 HDi turbo de' explosions
Post by teamster1975 » Tue Apr 28, 2009 11:44 am
Some garage wrote:The misfire is not apparent with a hot engine
Did you try changing the coolant temp sensor?
perils
Post by perils » Sun May 10, 2009 10:06 pm
Hi again,
Have changed the temp sensor now (3 days ago) and the problem is still there...
Euro car parts supplied the new sensor of the shelf, well done for that..
Now, I wonder what's next to change......?
I have cleaned the idle air control valve but wonder if I should get a new one....
Trouble is my symptoms go away once the engine has been at running temp for a while.
Any more ideas people ?
Cheers
Nick
2001 Yreg 406GTX
danbloke2000
Post by danbloke2000 » Sat May 16, 2009 11:19 pm
have tried to follow the instructions on this post and got stuck on the TDC sensor. My car does not appear to have one? Or, at least, in the place it is supposed to be in the post. Haines manual was of little help too.
I have tried many things, changed a few bits and still my fault is not cured. Basically it turns, fires then dies. If I am lucky then it will start and I can keep the revs up (with random engine complete stop) to a point where is it warm. it will then run.
most of the time it turns, fires a couple of times then dies.
supposed to be on holiday in it the end of the week.......not looking good.
so my question. where is the TDC on a 2L 16v R plate?
or any other suggestions much appreciated.
cars are a bit like marmite!
danbloke2000
Post by danbloke2000 » Sat Jun 06, 2009 1:26 pm
map sensor. changed it, all good. phew.
lukas
Post by lukas » Mon Jun 22, 2009 8:08 pm
Hi.
I have 406 1.8 16v 97y 93553 on the clock, it's my first car and I have problem with revs look everywhere in this cars should be 850-900rpm but I have little more than 1000 exactly is between 1000-1100 after when engine is warm its stays like that. I don't know what to do and it's little annoying ??
Help :? :? :? :? :? :? :?
keys84
Post by keys84 » Sun Jul 26, 2009 4:59 pm
Hi all i have exactly the same problem as lukas
i was thinkin the lambda sensor but not sure.
with sensor unplugged its exactly the same
is there any way to test the lambda sensor with a AVO/Circuit tester??
the exhaust smells very rich!!! and the MPG is abismal but i have been doin a lot of town driving so unsure on that.
any help would be Greatly appreciated as i love this motor
PS done 78k had recent service, and cam belt etc. is all up together
What ever the problem it has cooked my cat. and only passed the MOT by 0.01% :cry:
1996 Peugeot 406 1.8 16V
Post by teamster1975 » Sun Jul 26, 2009 10:28 pm
I've heard that the lambda sensor can cause rough idling, your emissions would be way off as well. Don't know how you test it though...
Post by mjb » Sun Jul 26, 2009 10:37 pm
I seriously need to unplug my lambda and put a variable sensor in its place so I can tell what it does to the car's behaviour....
Someone buy me a spare 406? ;)
RandollS
Post by RandollS » Mon Jul 27, 2009 6:06 pm
So will unpluging the Lambda sensor make the ECU think its giving a normal reading?
robb
Post by robb » Tue Aug 11, 2009 6:58 pm
followed the instructions now it stalls every time I let the revs down any ideas anyone :?
Post by steve_earwig » Tue Aug 11, 2009 7:57 pm
Which instructions?
robb
Post by robb » Tue Aug 11, 2009 8:03 pm
Sorry the stepper motor cleaning instructions :oops:
Post by steve_earwig » Tue Aug 11, 2009 9:01 pm
It made it worse? I think it's dead...
Locked
