406 exec Estate gearbox
cliffk
Post by cliffk » Mon Jul 16, 2018 10:16 am
Hi I have a 2003 2.0 hdi Estate and have just bought a 2001 2.0 hdi exec Estate
Reverse on my 2003 is over to the left and on the 2001 it's over to the right and down is this normal?
PeterN
Re: 406 exec Estate gearbox
Post by PeterN » Mon Jul 16, 2018 10:46 am
Yep, I have two '51 reg almost identical estates, on has reverse on the left the other on the right, most confusing when I change cars. I thought the l/h reverse was the later box but apparently not as my wife has an 03, 206 and that has the r/h side reverse.
Post by steve_earwig » Mon Jul 16, 2018 11:44 am
Early is ML5T, later is ML5C, Pug swear blind they're not interchangeable but the only difference I can see is the detent springs on the sychronisers changed.
Post by Doggy » Mon Jul 16, 2018 2:59 pm
+1 the ML5C (compact)? has a slightly shorter casing, (by about 10mm).
An ML6C is the same size as the ML5T and still has reverse beside 1st
cliffk
Post by cliffk » Mon Jul 16, 2018 3:06 pm
OK Thanks guys worries over
Post by steve_earwig » Mon Jul 16, 2018 4:23 pm
Now that I didn't know, all I can do is look at badly drawn pictures. Would that mean the gears themselves smaller/thinner? I.e. weaker...
PeterN
Post by PeterN » Tue Jul 17, 2018 11:19 am
I wouldn't worry about it, I have never had a 406 gearbox fail.
Post by Doggy » Tue Jul 17, 2018 12:52 pm
Think they're same, just more of.
As to longevity, mine did 70k in it's original cistern C5 & has tolerated 120k of 400Nm+ abuse since 2013. :supafrisk:
PeterN
Post by PeterN » Wed Jul 18, 2018 9:55 am
I have two with 200+k on them, very slight whine and 2nd baulks when cold, otherwise perfect.
