Non starting 2.0Hdi
jasper5
Re: Non starting 2.0Hdi
Post by jasper5 » Fri Mar 02, 2018 12:28 am
I don't think there should be any damage but I'm not sure.
I seem to remember there are both types fitted to the 307...a combined dpf and cat and a dpf only....couldn't say which one is fitted to this 307.
Post by Welly » Fri Mar 02, 2018 8:26 am
GingerMagic wrote:
Thu Mar 01, 2018 6:38 pm
I should feel a chuff chuff as the car is turning over
You should see your doctor about that.
I think the general idea is to disconnect the exhaust from the blockage as Jasper says, and try to start it.
If you try starts with the aid of easystart then quickly turn it off again if it catches, I don't think this is a good idea as the back pressure might cause other leaks around the turbo/eggsauce/egr/head etc.
Good luck!
2005 Volvo S40 T5 German Diesel botherer/i]
Post by Doggy » Fri Mar 02, 2018 1:34 pm
WCPGW?
Post by Welly » Fri Mar 02, 2018 4:32 pm
Post by GingerMagic » Mon Mar 26, 2018 10:34 pm
Well a quick update :oops:
A few days after my last post my friend got the car started, purely by chance as she was getting some important things out of the car and thought she would give it a go - bloody thing fired straight up..
It's been fine ever since, so maybe there was a bad connection on a sensor for the FAP, dunno really.
All good though for now, until the next issue..
1999 T4 family wagon
2005 Vauxhall Meriva
jasper5
Post by jasper5 » Tue Mar 27, 2018 12:28 pm
Stupid machines :(
Post by Doggy » Tue Mar 27, 2018 12:40 pm
There's always a reason, but it doesn't need to make sense. :roll:
