Peugeot 406 2.0 HDI 90HP, cold start problem
AndreiNCS
Re: Peugeot 406 2.0 HDI 90HP, cold start problem
Post by AndreiNCS » Fri May 18, 2018 1:14 pm
My only left solution, it will be to open the entire engine, and see if something it is broken in it, but I thnik I will do that on the autumn...
frog
Post by frog » Fri May 18, 2018 1:28 pm
To check for oil leak, you might do a less intruding analysis with an endoscope (small camera with a light in it on a flexible stick) to look inside the chambers when the engine is cold and has not run for a while.
Current "fleet":
2001 Citroen Saxo 1.6i 8v 100
Previously owned:
2000 406 Sedan 2.0 HDi 90
AndreiNCS
Post by AndreiNCS » Fri May 18, 2018 1:47 pm
Roger that! :cheesy: I will buy one only for this purpose!
Thank you!
jasper5
Post by jasper5 » Fri May 18, 2018 3:29 pm
From my experience your problem appears to be a classic glow plug fault or an injector issue.
The injectors you fitted were second hand, how do you know they are working perfectly?
AndreiNCS
Post by AndreiNCS » Thu May 24, 2018 12:14 pm
Hi jasper5 and sorry for this late response,
Yes, the injectors were second hand, but before putting them on the car, they we're tested on a special bench... I actually had tested 7 in order get 3 fully functional... most of them had values to high on the backflow circuit.
And I also replaced the glow plugs, and the glow plugs realy. What I can tell for sure, is that if I disconnect the coolant temp sensor, car starts almost good but still with a huge cloud of smoke.
AndreiNCS
Post by AndreiNCS » Mon Dec 03, 2018 3:48 pm
Hi guys,
Guess who's back?! Unfortunately with the same old problem. Last week I found the I haven't checked 2 sensors... the pressure on the common rail (code: 5WS40006) and there is also one more sensor ( code: 96356 92580 ), from my understadning this is for the diesel temperature.... anyway, I replace them with another ones from an engine just like mine wich has worked fine ( before going at parts dismantling) and the same poor starting.
I think I will buy one bottle of gasoline and I will set the car on fire! :evil: :evil: :evil:
