Odd idle speed behaviour
Post by FarmerPug » Sun Jan 28, 2018 11:10 am
My 406 (2.2 HDi) has a bit of an issue with its idle speed.
Normally it sits at about 900-950 rpm but if i move the car and freewheel then brake the revs dip down to 600 rpm as if its about to stall.
This would happen for example when reversing out of a parking space; the car is put into reverse, it backs out and when it has went back enough the clutch and brake are pressed, the car will then dip its revs to 600 rpm before returning to its normal idle speed.
the same happens if slowing down coming to a junction. It hasn’t stalled but it feels as if it is about to.
I thought perhaps the clutch wasnt disengaging fully when pressed down but this also happens if the car is put into neutral in these instances.
rwb
Re: Odd idle speed behaviour
Post by rwb » Sun Jan 28, 2018 5:32 pm
Could it be related to the clutch switch?
IIRC it has something to do with cutting revs when you disengage the clutch
Post by steve_earwig » Sun Jan 28, 2018 8:07 pm
I think it does the opposite, if the clutch is dipped while the car is moving it raises the idle. I think :?
Post by GingerMagic » Sun Jan 28, 2018 8:51 pm
Yeah, sounds to me the clutch switch isn't connected - I had the same symptoms on an old hdi90, after I unplugged the clutch switch.....
Is cruise control working?
1999 T4 family wagon
2005 Vauxhall Meriva
Post by FarmerPug » Sun Jan 28, 2018 9:35 pm
The cruise control works every time, on my old 110 it worked most of the time :lol:
Might need to get pp2000 plugged in, the clutch itself seems to sink after a few days of driving the travel becomes reduced, requiring it to be pulled back up with the foot although the actuation of the clutch seems to still be ok.
Post by Doggy » Mon Jan 29, 2018 1:56 pm
Normal idling speed is about 820 RPM on the tacho, or 790-odd via PP2k, (with the aircon turned off).
Maybe there's something odd with the ecu map - (I gather you may not know the origin of the one it's using)?
I can compare it with the 'normal' one if you want.
