nissens radiator 63705A
johntl
Post by johntl » Sat Dec 09, 2017 6:18 pm
Will not be long before need new rad as plastic cracked where bottom hose goes
I have seen some very cheap nissen radiators on e=bay, new old stock, my question is are all radiators for the 2.0 hdi 110 the same, mine is a 2001.
Are all the bottom hose fittings the same internal type, ca..... type?
The type on e-bay are nissen 63705A £20! are they a decent make , danish I think
Re: nissens radiator 63705A
Post by steve_earwig » Sat Dec 09, 2017 9:02 pm
It's a bit confusing (Hot climates, air conditioning, BVA/M) but it looks like they never changed across production, so if your car's a 2.0 110 manual with air con, no FAP and you don't live in the Sahara then if you get one for a 2.0 110 with air con, no FAP & made for Finland it'll be the same thing.
Wonder if D8's were different... Er yes they were.
johntl
Post by johntl » Sat Dec 09, 2017 10:37 pm
cheers steve,
just wundered if there was any difference between pre 2001 and post 2001 as mine is on the borderline, may 2001 ,yes mine is 110 with just a cat and air-con .the bottom hose seems to be different to the ones advertised, it has a T in it 6 inch from the bottom.
Post by steve_earwig » Sat Dec 09, 2017 11:11 pm
It's what Service Box is telling me and it's probably correct.
I'm a bit befuddled here, you're looking at radiator hose pictures in an ad for a radiator, or you're looking for the hose too? That rad also fits an EW7J4, maybe that' what's in the pic. I don't think I can find the same thing on the bay, there's 1 for 20 quid but there's no rad hoses anywhere.
Nissens, while not Valeo, still have a fair name. I reckon for 20 quid it must be worth a punt, unless you have fears of it letting you down in the middle of nowhere (like it would me...)
johntl
Post by johntl » Sun Dec 10, 2017 10:33 am
yes I've been looking at both rad and bottom hose as you might as well change both
johntl
Post by johntl » Sun Dec 10, 2017 10:39 am
Its been cracked for nearly 2 yrs , with a couple of tie-wraps on, its about time, I've been tempting fate for a while now
Post by steve_earwig » Sun Dec 10, 2017 11:20 am
Ah, I get you now. The part number looks like 1381Z9, seems to be the same for plastic and ali housings.
there's one here with a T on it https://www.ebay.co.uk/itm/PEUGEOT-406- ... SwRQlXdjRk
johntl
Post by johntl » Sun Dec 10, 2017 11:30 am
Yes thats the one, thanks for your input steve, had the car 7 yrs now still going strong 166k, only issue is the old 406 problem - sills !!!
johntl
Post by johntl » Mon Dec 25, 2017 5:58 pm
Just got delivered both rad and bottom hose, just have to get round to getting them fitted,
they look spot on , but will let you know if there is any probs !
Post by steve_earwig » Mon Dec 25, 2017 6:04 pm
You got a delivery on Christmas day? :shock: Did arrive via your chimney? :cheesy:
I hope it all goes on ok!
johntl
Post by johntl » Mon Dec 25, 2017 8:30 pm
LOL :lol: not quite, radiator came quite quick, but hose was a week late from poland came on friday !
will let you know
MERRY CHRISTMAS
