90 to 110
dave406
90 to 110
Post by dave406 » Sun Oct 22, 2017 8:32 pm
whats need to conver t a hdi 90 to 110
Re: 90 to 110
Post by Doggy » Sun Oct 22, 2017 9:06 pm
Short answer is too much to make it worthwhile.
Either swap the car for a 110/2.2 or pay for a remap to give you about 125 bhp for something like £80
dave406
Re: 90 to 110
Post by dave406 » Sun Oct 22, 2017 11:08 pm
Not for me someone posed the question regarding the car I'm breaking
PeterN
Re: 90 to 110
Post by PeterN » Mon Oct 23, 2017 11:18 am
I wouldn't have thought that fitting the intercooler would be much of a problem if you have a donor car for the hoses etc. I appreciate that the fuel delivery will need to be increased could that not be programmed - just curious.
Re: 90 to 110
Post by Doggy » Mon Oct 23, 2017 12:45 pm
90's have a mechanical wastegate, 110's are controlled by the ecu & have a MAP sensor & wiring, so ecu firmware is different....
The ecu's matched to the BSI and ignition transponder, so not easy to swap that over
Later 90's have Siemens fuel system, no lift pump and a completely different fuel pressure regulator set-up
piglet
Re: 90 to 110
Post by piglet » Mon Oct 23, 2017 2:31 pm
Doggy wrote: pay for a remap for something like £80
You might be a bit out of touch.
Re: 90 to 110
Post by Doggy » Mon Oct 23, 2017 9:54 pm
You're right.
hdi-tuning.co.uk wrote:Online Remap 2.0 or 2.2 EDC15 £99.00 GBP
PeterN
Re: 90 to 110
Post by PeterN » Mon Oct 23, 2017 10:25 pm
Doggy wrote:90's have a mechanical wastegate, 110's are controlled by the ecu & have a MAP sensor & wiring, so ecu firmware is different....
Right thanks, didn't realise that.
dirtydirtydiesel
Re: 90 to 110
Post by dirtydirtydiesel » Mon Oct 23, 2017 10:45 pm
Yes all above is correct but,
The 90's can be remapped to 150bhp,
The intercooler is easy enough to retro fit,
As others have said pop over to hdi-tuning.co.uk for more information :D
Re: 90 to 110
Post by Welly » Tue Oct 24, 2017 11:20 am
Doggy wrote:You're right.
Please desist in misleading members with your inaccurate information :P
Whilst I'm at it can you get me a price for a new back box? you seem cheaper than most online places I've found, thanks.
2005 Volvo S40 T5 a bit pampered, taking bookings from nice* VAG owners
Re: 90 to 110
Post by Doggy » Tue Oct 24, 2017 12:47 pm
Certainly, Cistern or Vulva?
dirtydirtydiesel
Re: 90 to 110
Post by dirtydirtydiesel » Tue Oct 24, 2017 9:10 pm
:arrowu: :lol: , l.m.a.o :arrowu:
ps. Anyone find a bosal for the estate :roll:
fattail95
Re: 90 to 110
Post by fattail95 » Wed Oct 25, 2017 2:07 pm
Easy conversion if its just the intercooler, you will need all the 110 pipework and the elbow on the intake manifold and away you go. To take advantage of the charge cooler, you will need a remap and you can make pretty much the same power as the 110. You will have to manually increase the boost on the 90 as it is controlled by a mechanical wastegate (0.9bar factory I think), so the rubber vacuum hose will have to be cut and a bleed valve added if you want to take it past ~125hp. Be aware though that the HDi 90 crank is different to the 110 crank (which is burnished) and can therefore take less abuse. As such, with a 90 vs 110 mapped to the same power the 90 will wear faster. My 110 is currently running 1.4bar boost with a max fuel delivery of 80mm^3/str between 2300rpm-3200rpm. This gives an estimated 330nm/150hp with a much nicer torque curve than standard, and is +80nm and +40hp. We all know Pug likes to undertune engines and these are bulletproof so gains like this are no problem as long as good maintenance is carried out on the vehicle and the crucial components (most notably injectors, dmf, turbo and bottom end) are in good order.
I've done a lot of research into the DW10 engine so if you have any questions, shoot me a PM.
Best Regards,
Ben.
PeterN
Re: 90 to 110
Post by PeterN » Wed Oct 25, 2017 3:56 pm
Thanks for that Ben, I have run four of these engines and have had no problems until my wife's lost power below 2000 rpm which I think is a turbo control issue, suddenly comes to life at 2000 rpm. I have yet to check all the vacuum hoses. We have been driving it like this for sometime and generally its OK unless you are suddenly confronted with a steep hill. I have swapped the MAF with mine and it makes no difference.
The power output of the 110 hp suits me fine so I'm no bothered about improving it, 50 years ago maybe :wink: I still do a fair mileage but mostly in the slow lane. Mind you I drove a 206 90HP the other day and that took off, reminded me of the BX turbo - and about as refined. :(
fattail95
Re: 90 to 110
Post by fattail95 » Fri Oct 27, 2017 8:50 pm
There's not only power to be gained from a map, the additional fuel economy and refinement brought from the broader, more usable torque curve brings the car to life. As much as the standard output map may suit you, I know you'd be much happier with it mapped. Not to mention the map will eventually pay for itself in fuel savings. :D
