fast idle
straggler
fast idle
Post by straggler » Sat Oct 14, 2017 11:32 am
I have a 96 406 XUDT with the Bosch fuel system.
The tickover speed is high (around 950rpm) and I can't adjust it out. Bizarrely, it drops to around 800rpm when at high altitude (like at the top of a Norwegian mountain).
Is there anything that's not the tickover screw I could check?
PeterN
Re: fast idle
Post by PeterN » Sat Oct 14, 2017 12:52 pm
Does this pump have an anti stall adjustment? if so it could be that its set to high. Could be that was only CAV pumps.
