406 90 HDI core plug
DefTrap
Post by DefTrap » Tue Aug 22, 2017 1:31 pm
One is blowing, driver's side, and I'm considering fixing it with JB chemical metal putty as the garage quote isn't viable on a 180k car.
Anyone ever done this on the 406? Looking for advice on how best to access as so far access is by touch only, I'd be working blind. Bonnet off make it easier?
scoopeydiesel
Re: 406 90 HDI core plug
Post by scoopeydiesel » Tue Aug 22, 2017 10:48 pm
I done one maybe two plugs on the rear of the engine. It was a pig of a job and from memory i did it from underneath by removing some stuff. Not a nice job !!
PeterN
Post by PeterN » Wed Aug 23, 2017 10:29 am
If you are going to use filler of some sort you will need to get it scrupulously clean which is difficult if you can't get to it but I would suspect that spraying a strong solvent into it might do it, something like carburetter cleaner or cellulose thinners might work.
I remember changing one at the back of the cylinder head on a Humber Super snipe many years ago, I made up a tool that went between the head and bulkhead to push it in by screw pressure, it only went partly in but it stayed there.
DefTrap
Post by DefTrap » Thu Aug 24, 2017 8:12 pm
Its done now anyway.
Dumped all the coolant and let it drain for a day, then got as much solvent splashed around the area as possible and dried off again before putting the putty in. It seems rock solid but time will tell I spose.
Tomorrow I'll fill it up and test.
PeterN
Post by PeterN » Thu Aug 24, 2017 9:25 pm
As long as some went through the hole it should have a good key. I have on a couple of occasions fixed the leak on a radiator with putty!
DefTrap
Post by DefTrap » Sat Aug 26, 2017 5:01 pm
Seems to have done the trick so far anyway
