po380
binnzy
po380
Post by binnzy » Wed Mar 15, 2017 8:30 pm
Hi, 406 110 2001, car fires once then just turns over, try again just turns over, wait 1/2 hour car fires once just turns over. code reader says po308 glow plug heater circuit A, I have put in new glow plugs relay puts power to the glow plugs on the key but still the same, anyone got any ideas please.
If it doesn't fit you need a bigger hammer
Re: po380
Post by steve_earwig » Wed Mar 15, 2017 8:37 pm
Sadly the glow plug error is common but it means little, plus they don't actually do much above freezing.
Lift pump running?
binnzy
Re: po380
Post by binnzy » Wed Mar 15, 2017 8:46 pm
I can here the pump when I turn on the ignition,
Re: po380
Post by steve_earwig » Wed Mar 15, 2017 9:01 pm
That's about the limit of my knowledge I'm afraid :( Needs some proper diagnostics with PP I reckon.
PeterN
Re: po380
Post by PeterN » Thu Mar 16, 2017 12:46 am
Sounds like a fuel line pressure problem, first thing to check is the fuel filter if it hasn't been changed lately. The pressure regulator on the back of the HP pump can give all sorts of problems but as Steve says a PP200 session may give you a stored fault or fuel pressure when cranking.
binnzy
Re: po380
Post by binnzy » Thu Mar 16, 2017 10:33 am
Anybody out there with pp2000 near chorley Lancashire.
