Vacuum solenoids
Vacuum solenoids
Hi all im after some information on what solenoid is for what.. Im guessing the 3 on the bulkhead are turbo solenoid nearest the drivers side then egr? Then?? Also the other solenoids what do they control and can they be deleted ie dozer valve? Thanks
- GingerMagic
Re: Vacuum solenoids
All the solenoids can be deleted ( removed vacuum but not the connector unless remapped accordingly ) apart from the turbo and swirl, even the swirl can be bypassed to eliminate it as a possible leak, as can the vacuum reservoir under the servo.
viewtopic.php?f=1&t=24454Matcoupe80 wrote:Hi all im after some information on what solenoid is for what.. Im guessing the 3 on the bulkhead are turbo solenoid nearest the drivers side then egr? Then?? Also the other solenoids what do they control and can they be deleted ie dozer valve? Thanks
1999 T4 family wagon
2005 Vauxhall Meriva
