FUEL PRESSURE REGULATOR
panadero
Post by panadero » Fri Jan 06, 2017 7:45 pm
Does anyone know if the fuel pressure regulator attached to the hp pump on a 406 2.0 hdi (04) can be tested off the car?
If so I will remove it and take it to be tested rather than drive the car to the garage as it could well stall en route. Alternatively I am thinking of simply replacing it with a cheap second hand regulator as a matter of course just to see if this will cure the fault.
charliedog
Re: FUEL PRESSURE REGULATOR
Post by charliedog » Mon Jul 03, 2017 9:38 pm
Pandora, Did you manage to fix your FPR problem? If so what was it? I have a similar problem
PeterN
Post by PeterN » Tue Jul 04, 2017 9:28 am
The usual problem with them is that the filter gets blocked, it's the thing on the end that looks like a stainless steel tube only it has minute holes in it which I can't see although it has a rough feel to it. If you can find a way of cleaning it fine but I fitted a cheap secondhand one and it was OK. As long as it comes from a working car it should be alright. Some of them don't have the filter.
dirtydirtydiesel
Post by dirtydirtydiesel » Tue Jul 11, 2017 6:58 pm
I have just got round to replacing mine :roll: .
Here's a few pictures with some descriptions.
So here's the fuel pressure regulator ( old one in picture ) with the fuel filter & housing removed for easy access.
You need to clean up the fuel filter housing spotlessly clean BEFORE removing the fuel pipes, so as not to contaminate
the fuel system :roll:
It'll is also a good idea to block off the three fuel pipes ( good filter kits include these)
I also swing the three fuel pipes out of the way for easier access :D
Fuel pressure regulator removed.
It's also a good idea to spotlessly clean the fuel pump where the pressure regulator fit's.
For cleaning I use AC90, it's just like WD40, GT85 ect, but I get mine from work :wink:
Just for the record the tools needed are 3/8 wrench, 150mm extention & 75mm extention, 10mm socket, 6mm hex bit that fit's into socket extention, 3/8 wobble bar & torx 30 bit + small hammer, small bit of soft wood (12mm x 150mm) aprox, tub for old diesel & tooth brush for cleaning :)
Old & New Fuel Pressure Regulators, genuine Bosch one from Ebay :cheesy:
The new metal gasket does not come with the regulator, I got one from? , yes ebay :wink:
New fuel pressure regulator fitted, before fitting lube the o-ring with clean diesel.
All back together :cheesy: , just the engine cover to replace,
I would strongly advise fitting a new fuel filter when carrying this out, & fill up the filter housing 3/4 full with clean diesel or diesel cleaner BEFORE refitting the new filter :) .
Take for test drive & find out that it's no fxxxxxg different :x.
So I can only hope it cures my low fuel pressure when towing :roll: .
My old perfectly serviceable unit will be cleaned as per pro Steve's instructions from (HDI tuning) , fitted with new seals and gasket
& Advertised on here & ebay.
When I get back from my holiday 8) .
Hope this is of some help to other's.
Ps I checked my fuel pressure using pp2k & I am seeing 1345 bar, so no problems there :?
I will be quizzing you all on injector correction values though when I get back :roll:.
Latter's DDD 8) .
dirtydirtydiesel
Post by dirtydirtydiesel » Sun Jul 30, 2017 6:52 am
So I'm back & guess what,
The new fuel pressure regulator didn't fix my problem when towing :(
I'm starting to think she's protesting at towing the caravan :lol:
Lot's more testing to be done, will post back later with more details / info / questions :wink:
PeterN
Post by PeterN » Sun Jul 30, 2017 8:35 am
I have never had an injector fail on a 406 Hdi 8 valve - there's always a first time of course.
Post by Doggy » Sun Jul 30, 2017 8:59 pm
Leak-off test would be my next move.
As a matter of interest, how bad are your injector correction values?
dirtydirtydiesel
Post by dirtydirtydiesel » Mon Jul 31, 2017 6:54 pm
Hi Doggy,
Yes I'm thinking the same, from memory 2 were + something & 2 were - something :roll:
I will have a session with pp2k & record the values.
