engine stops while in moving
yamta
Post by yamta » Sat Dec 31, 2016 4:40 pm
hello,
i own a 406 2.0. and right now it keeps going off while am moving with it. it started after it was diagnosed and the coil was replaced. after that i have changed fuel pump, fuel filter and the key. it still stops while in motion.
Sometimes when it stops it makes a pop sound and then the engine keeps running or shuts down completely. I think it's the coil that's not good but can you help advise please.
please help. :cry: :cry: :cry:
yamta
Re: engine stops while in moving
Post by yamta » Fri Aug 25, 2017 1:48 am
this problem was solved by replacing the ECU with accompany cables to the engine etc. + proper spark plugs. with two hooks
