6-Speed Gearbox
Re: 6-Speed Gearbox
Post by steve_earwig » Sat Aug 03, 2013 3:41 pm
Wow! That 6 speed just keeps getting better and better :cheesy:
nutski
Re: 6-Speed Gearbox
Post by nutski » Sat Aug 03, 2013 3:45 pm
Sounds good Doggy, mines getting fitted on Friday and if i get a similar improvement mine will pay for itself in 6 months!
1997 2.1 TD Exec (Sold)
1997 3.0 V6 Coupe S (Sold)
2001 406 HDi 110 GTX (Sold)
2002 406 Coupe HDi SE (RIP)
2001 406 Coupe 3.0 V6 SE
2003 406 2.2 HDi SE
Re: 6-Speed Gearbox
Post by Doggy » Sat Aug 03, 2013 6:45 pm
V6Exec wrote:Obvious question; based on before and after MPG, what is the break even point for the gear box?
Depends on whether you use the basic cost of 'box + fitting, (in round numbers about £350). or count the clutch & DMF too, (nearer £700).
Anyways, I do about 21k/year. if we say 44 mpg before and 47 after, at £1.40 / litre, annual saving's about £300. Clearly. it's not a formula for saving money, but it's so much nicer to drive - for example, no engine noise at 110 is pretty cool.
nutski wrote:Sounds good Doggy, mines getting fitted on Friday and if i get a similar improvement mine will pay for itself in 6 months!
That's what I like to hear. 8) Hope it all goes as easily as mine did.
Re: 6-Speed Gearbox
Post by FarmerPug » Wed Aug 07, 2013 11:18 pm
Doggy, i was looking on service box characteristics to find out the gearbox my car is fitted with, and it says ML5C. Is that the same as your original 5 speed box?
Re: 6-Speed Gearbox
Post by Doggy » Wed Aug 07, 2013 11:56 pm
Frank, my old one was an ML5C too, but there are some differences, The clutch housing is different, (I think), to accomodate the 2.2's bigger flywheel and clutch, also I understand there is a small difference in the final drive ratios.
ML5C's come is several versions, mine was a code 20LM02, whereas I think yours will be a 20LM04
Re: 6-Speed Gearbox
Post by FarmerPug » Thu Aug 08, 2013 12:06 am
It says transmission BVM5 on service box, no other codes unfortunately, is the 20LM02 (or 20LM04) stamped somewhere on the car or gearbox.
Re: 6-Speed Gearbox
Post by Doggy » Thu Aug 08, 2013 12:41 pm
It's somewhere on the gearbox casing, (can't remember where, but I'll try to have a look at the one in the shed at the weekend).
Also, on servicebox, if you look up spare parts, gearbox, then pick the diagram entitled 'manual gearbox' it should show the gearbox code, (or at least the last 4 digits, along with the part number), e.g. 'LM04'.
Re: 6-Speed Gearbox
Post by FarmerPug » Thu Aug 08, 2013 6:30 pm
Thanks, checked servicebox i have the LM04 gearbox:
(out of interest peugeot part prices are £4615.97 for a new box, and £2786.64 for an exchange one :shock: )
Ill need to look at 407's then for a 6 speed box then?
Re: 6-Speed Gearbox
Post by GingerMagic » Thu Aug 08, 2013 7:21 pm
Is the LM04 a down-right reverse, and the LM02 a lift and top-left reverse?
Maybe an easier way to tell which is which...
Mines a LM02 which is the same as Doggys old one, lift and top-left reverse.
1999 T4 family wagon
2005 Vauxhall Meriva
Re: 6-Speed Gearbox
Post by lozz » Thu Aug 08, 2013 7:35 pm
FarmerPug wrote:Thanks, checked servicebox i have the LM04 gearbox:
How much... :shock:
Are they a'vin a tin bath, you can buy a nearly new car for that, :?
Re: 6-Speed Gearbox
Post by FarmerPug » Thu Aug 08, 2013 8:18 pm
GingerMagic wrote:Is the LM04 a down-right reverse, and the LM02 a lift and top-left reverse?
I have a lift and top left reverse on my 2.0, the car im breaking the 90 and the 110 i broke a couple of years ago had the reverse below 5th
Your right lozz, its just bonkers, you could buy a lorry load of 406s with good gearboxes for the price peugeot wants for one
Re: 6-Speed Gearbox
Post by Doggy » Thu Aug 08, 2013 9:04 pm
Lift for reverse = ML5C, aka 'compact', reverse back from 5th = ML5T, (as far as I can tell), seems the boxes are virtually the same, bar reverse interlocking.
FarmerPug wrote:Ill need to look at 407's then for a 6 speed box then?
You need to be careful, Frank.
a). jasper5 reckons the DMF/clutch on his 2.0 16V HDi is a lot bigger and the housing therefore might be too.
b). many 407's have 16" or 17" wheels, so have lower final drive ratios to compensate - you could wind up lower geared if you're not careful.
My 6-speed came from a late 2003/early 2004 C5, which came with 215/55/16 tyres, (like a 406 coupe or late 406 SE), so has the same final drive ratio, same 1st, 2nd, 3rd & 4th, a fractionally lower 5th gear and obviously 6th is higher.
Worth your while reading this thread from the beginning and checking out this one from the coupe forum http://www.406coupeclub.org/PHPBB3/view ... 22&t=42765
grey
Re: 6-Speed Gearbox
Post by grey » Sat Aug 10, 2013 7:01 pm
Great write up and result, can you do similar to a 2.0 HDi?
Re: 6-Speed Gearbox
Post by Doggy » Sat Aug 10, 2013 10:06 pm
grey wrote:Great write up and result, can you do similar to a 2.0 HDi?
Honestly don't know, I would be amazed if you can't find one that would fit, but in my mind at least, there's not enough justification unless it delivers much better cruising, (note comments about ratios / final drive / wheel sizes).
grey
Re: 6-Speed Gearbox
Post by grey » Sun Aug 11, 2013 12:51 pm
True, it would have just been a mod for the sake of a mod :cheesy:
